Link expired or not operational.
Luke Routh 0 Reputation points
2026-01-23T15:38:36.5566667+00:00
how do i replace an expired link on my website?
here is the issue from my website's link...
1/23/2026 3:21:32 PM UTC NAM ca95bbbc-d845-485b-8d4a-25bfc9b92deb
Azure Web PubSub
Azure Web PubSub
An Azure service that provides real-time messaging for web applications using WebSockets and the publish-subscribe pattern.
  1. Christopher Corder 5 Reputation points Microsoft Employee
    2026-01-23T23:59:26.99+00:00
    The error and timestamp you provided indicate that an Azure Automation Webhook has expired.
    In Azure, webhooks have a hard expiration date. Once a webhook expires, the URL becomes permanently invalid (returning a 400 Bad Request or "Link Expired" error), and for security reasons, it cannot be renewed or reactivated.
    To fix your website link, you must create a new webhook and update your website's code with the new URL.
    Step 1: Create a New Webhook in Azure
    Select Create new webhook:
    Name: Give it a descriptive name (e.g., Website_Trigger_2026).
    Enabled: Set to Yes.
    Expires: Set this to a date further in the future (e.g., 1 or 2 years).
    URL: [CRITICAL] Copy the URL immediately. You will never be able to see this URL again once you click OK.
    Step 2: Update Your Website
    Once you have the new URL (which will look like https://<region>.webhook.azure.com/webhooks/...), you must replace the old link in your website's configuration or code.
    If it's a button/link: Replace the href or the API endpoint URL in your HTML/JavaScript.
    If it's a backend trigger: Update the environment variable or configuration file where the webhook URL is stored.
  2. Anak Roy 0 Reputation points
    2026-01-26T18:21:52.0733333+00:00
    Did your friend send the money? If you did, it would be very beneficial for you. The reason is that my friend will stand by me. So send it quickly. Do you still believe? No, if you don't believe me, then tell me, I'll take another picture and send it to you. They're redoing everything again.
  3. Anak Roy 0 Reputation points
    2026-01-26T18:24:43.91+00:00
    Thank you all so much for liking me or sharing, but friends, I am in a problem now. If I can get out of that problem, I will talk to everyone again. My hand is broken.Because I am admitted in medical school, so I can't meet or talk to anyone, but I can message you anyway. So I will reply to your messages occasionally. But please support me a little so that I can fix my hand. I want to return home as soon as possible, I have only one request to all of you. Please help me a little. I only have to pay the doctor's bill of one lakh taka. And four months I have to stay at home and can't do anything. I'm dying to think about how I'm going to move on.
  4. Anak Roy 0 Reputation points
    2026-01-26T18:41:57.03+00:00
    So send it the way it is sent, you can withdraw cash and send it, if you send it, I will transfer it to your account. Please. Please help me.
