I have surface studio and am unable to connect airpods pro 2
Piyush Pandit 0 Reputation points
2026-01-19T03:23:43.0533333+00:00
I have Airpods pro 2 and Airpods 4 , Pro 2 cannot connect via bluetooth and airpods pro 4 does not worki with MS Teams, Please help
Surface | Surface Studio | Install and update
    2026-01-19T03:23:50.1033333+00:00
    To connect your AirPods Pro 2 to your Surface Studio, ensure that your Surface Studio meets the minimum requirements for Bluetooth connectivity. Here are some steps to troubleshoot the connection issue:
    1. Check Bluetooth Settings: Make sure Bluetooth is enabled on your Surface Studio. Go to Settings > Devices > Bluetooth & other devices and ensure Bluetooth is turned on.
    2. Pairing Mode: Place your AirPods Pro 2 in pairing mode. To do this, open the lid of the AirPods case and press and hold the button on the back of the case until the light flashes white.
    3. Add Bluetooth Device: In the Bluetooth settings on your Surface Studio, click on Add Bluetooth or other device, then select Bluetooth and choose your AirPods from the list.
    4. Driver Updates: Ensure that your Bluetooth drivers are up to date. You can check this in Device Manager under Bluetooth. Right-click on your Bluetooth device and select Update driver.
    Regarding the AirPods Pro 4 not working with Microsoft Teams, it's important to note that only Teams-certified peripherals guarantee full functionality with the Teams app. If your AirPods Pro 4 are not certified, you may experience issues such as audio not syncing or controls not functioning properly. For optimal performance, consider using Teams-certified devices.
    If you continue to experience issues, you might want to refer to the Bluetooth troubleshooting steps provided by Microsoft Support.
  2. Piyush Pandit 0 Reputation points
    2026-01-19T03:24:24.4466667+00:00
    I have tried all these steps couple of times, still same issue
