Using WinUI 3 without XAML
Tommer Francis 0 Reputation points
2026-01-16T07:40:15.6366667+00:00
Hello everyone, I would like to know that how to use WinUI 3 without XAML. Thank you very much.
Developer technologies | XAML
A language based on Extensible Markup Language (XML) that enables developers to specify a hierarchy of objects with a set of properties and logic.
  1. Danny Nguyen (WICLOUD CORPORATION) 8,725 Reputation points Microsoft External Staff Moderator
    2026-01-16T08:16:48.5133333+00:00
    WinUI 3 is fundamentally a XAML-based UI framework, so “using WinUI 3 without XAML” isn’t really a supported/realistic approach for normal app development.
    As the official docs WinUI3 describe it:
    “WinUI 3 is Microsoft's modern native user interface framework for building Windows desktop applications. It brings the Fluent Design System, high-performance rendering, and a powerful XAML-based programming model to both C# and C++ developers.”
    So if your goal is to avoid XAML entirely, you’ll likely want to choose a different UI approach/framework.
