Managing and troubleshooting browser extensions in Edge on iOS
Disappeared overnight from Microsoft Edge (no update involved) How do I restore Collection?
AI answer
If your Collections feature in Microsoft Edge has disappeared, there are a few steps you can take to try to restore it:
If none of these steps work, you may want to consider resetting your Edge settings or reinstalling the browser as a last resort.
Thank you for sharing your question. You’ve already confirmed there's been no recent update, and this happened unexpectedly, which makes the disappearance even more puzzling.
Empathy: It’s completely understandable to feel alarmed and frustrated; losing the Collections feature feels like losing notes, ideas, and saved pages all at once.
Reason and resolution: Edge Collections are tied to your profile and sync settings, so the most likely causes include a sign‑in or sync hiccup, profile switch, or UI toggle being inadvertently disabled. To restore them, first confirm you’re signed into Edge with the correct Microsoft account. Then go to Settings → Profiles → Sync and ensure Collections sync is toggled on. Next, restart your browser to refresh temporary glitches, and check for any pending browser updates. Open an InPrivate window if Collections reappear there, it's a profile-specific or sync cache issue. If all that checks out but Collections still don’t show, you may need to reset Edge settings or reinstall the browser as a clean start, though your data should be retained or recoverable via sync.
I hope this helps.
Best Regards,
Noel
The latest update to the iOS Edge app seems to have rectified the issue.
