A collaborative workspace app in Microsoft 365 designed to help teams co-create, stay organized, and work together in real time across apps and devices.
Hi, Tomic, Mijat
Welcome to Microsoft Q&A forum.
Thanks for your question. Currently, a table on a full Loop page can use the page’s wider canvas and “expand” controls, but the same table shared as a Loop component is rendered inside a fixed-width frame (Teams, Outlook, etc.), so the “expand to show all columns” experience is not available there.
Here are some alternatives you can try:
1) Open the component in the full Loop page view (best option)
When you need to see everything at once, open the component in Loop instead of working inside the embedded frame. In most hosts you can use the component header menu (or copy the component link) to Open in Loop / Open in browser, then view and work with the table on the full page canvas.
2) Keep the “key columns” visible by hiding or reordering columns
If the component must stay embedded, a practical approach is to:
- Move the most important columns to the left
- Hide rarely used columns so the table fits without constant horizontal scrolling
3) Zoom out to fit more columns on screen
Not elegant, but it works quickly. In the host app or browser, reduce zoom (for example with Ctrl + mouse wheel) so more columns fit in the component frame.
4) Split the table into two smaller tables (or a “summary” + “details” table)
If you consistently have many columns, splitting usually makes the embedded experience much nicer:
- Table A: the columns people reference all the time
- Table B: the extra columns (linked from Table A with a row name or ID)
5) Use row “detail view” for extra info instead of more columns
If your extra columns are really “details per row,” consider moving them into the row detail pane, and keep the main table narrower for embedded viewing.
6) Send feedback
If the goal is “full-width / expand” inside components, it’s worth submitting feedback from Loop (Help > Give feedback). This is one of those areas where enough feedback tends to drive improvements.
Hope this helps. Feel free to get back if you need further assistance.
If the answer is helpful, please click "Accept Answer" and kindly upvote it. If you have extra questions about this answer, please click "Comment."
