Cannot navigate Azure portal using the Edge or Chrome browsers.
Christopher Crawford 0 Reputation points
2026-01-13T13:28:10.7266667+00:00
Can no longer navigate Azure portal using Chrome or Edge browsers. It hangs up on most of the Azure tasks or pages. I am using the Firefox Browser now and that is working fine....This issue started about 1 month ago.
Azure Cloud Services
An Azure platform as a service offer that is used to deploy web and cloud applications.
    2026-01-13T13:28:18.47+00:00
    If you are experiencing issues navigating the Azure portal using Chrome or Edge, here are some troubleshooting steps you can try:
    1. Refresh the Page: Sometimes a simple refresh can resolve loading issues.
    2. Use Private Browsing Mode: Try accessing the Azure portal in private browsing mode (Incognito in Chrome or InPrivate in Edge). This can help bypass any caching issues.
    3. Clear Cache and Cookies: Clearing your browser's cache and cookies can often resolve loading problems. In Edge, you can do this by going to Settings > Privacy and Services > Clear Browsing Data. In Chrome, go to Settings > Privacy and Security > Clear browsing data.
    4. Check for Browser Updates: Ensure that you are using the latest version of your browser.
    5. Disable Extensions: Sometimes browser extensions can interfere with website functionality. Try disabling them temporarily to see if that resolves the issue.
    6. Reset Browser Settings: If the problem persists, consider resetting your browser settings to their defaults.
    If you continue to experience issues, it may be beneficial to reach out to Microsoft support for further assistance.
