How to disable Teams mini popup window in calls
Joseph 25 Reputation points
2026-01-12T22:11:08.9966667+00:00
I work off my macbook and find it very frustrating that i cannot disable the mini popup window that generates anytime i either minimize or change to another screen
I have seen in other posts to "extend" the Teams window to another screen but i cannot get this to be the case between the virtual Parallels full screen and my main screen
Microsoft Teams | Microsoft Teams for business | Teams for Mac
AlexDN 11,450 Reputation points Microsoft External Staff Moderator
2026-01-13T02:38:56.2633333+00:00
Dear @Joseph,
Thank you for posting your question in the Microsoft Q&A forum. I understand that when the Teams call window keeps turning into a small popup while you are working on another screen, especially on a Mac.
On Microsoft Teams for Mac, the mini popup window that appears during a call when you minimize Teams or switch to another app is an expected behavior by design. At this time, Teams on macOS does not provide an option to fully disable this floating call window.
This behavior becomes more noticeable when using Parallels in full‑screen mode, as macOS treats Parallels as a separate screen space. In that setup, Teams cannot stay extended between your main Mac screen and the Parallels screen, so it automatically switches to the mini call window to keep the call visible and accessible.
At the moment, the following may help reduce the impact, even though they do not completely disable the popup:
  • Keep the Teams call window open in the background instead of minimizing it
  • Run Parallels in windowed mode rather than full‑screen, if possible
  • Keep Teams and Parallels within the same macOS desktop.
Moreover, If this behavior is affecting your workflow, you can also share feedback directly with the Teams product team. I want you to know that Microsoft deeply values customer experience and feedback. Every single comment matter, and the product teams actively review what customers share to guide decisions and improvements. Your voice is powerful here, and I encourage you to make it heard through the official feedback channels. Therefore, to ensure your feedback reaches the right teams, I highly recommend submitting your feedback directly to Microsoft Ideas · Community, where our product development team can know your requirements and ideas for product improvements. If enough users raise ticket for the same idea, Microsoft may consider adding this feature in the future.
Note: As Microsoft Community moderators, please note that we are not involved in product design decisions and do not have direct access to the development roadmap, we want to assure you that your feedback has been acknowledged and is valued.
However, you can rest assured that you are not alone, I’ll continue to monitor this case and will reach out to you with any new updates as soon as possible. If any updates or announcements are made regarding this feature, I will make sure to share them with you as soon as possible.
I understand this may not be the outcome you were hoping for. I truly appreciate your patience and understanding. If you have any further questions or need further clarification, please feel free to reach out. I'm looking forward to hearing from you.
Thank you for your cooperation.
If the answer is helpful, please click "Accept Answer" and kindly upvote it. If you have extra questions about this answer, please click "Comment".
Note: Please follow the steps in our documentation to enable e-mail notifications if you want to receive the related email notification for this thread.
2 additional answers
  1. Deleted
  2. AI answer
    2026-01-12T22:11:13.43+00:00
    Currently, there is no specific setting in Microsoft Teams for Mac to disable the mini popup window that appears during calls when you minimize or switch screens. This behavior is part of the Teams interface and is designed to keep users informed about ongoing calls.
    If you are using Teams in a virtualized environment like Parallels, you might experience additional limitations regarding window management. Extending the Teams window across multiple screens can sometimes help, but it may not function as expected in all configurations, especially with full-screen applications in Parallels.
    For a more tailored solution, consider providing feedback to Microsoft through the Teams app, as user feedback can influence future updates and features.
