It sounds like you're experiencing issues with enrolling your new Surface Pro Laptop into your company's Intune setup. Here are some troubleshooting steps you can consider:
- Check Enrollment Restrictions: Ensure that there are no device type restrictions that might be blocking the enrollment of your Surface Pro. You can check this in the Microsoft Intune admin center under Devices > Enrollment restrictions.
- Device Limit: Verify that the device enrollment limit has not been reached for your account. You can increase the device limit if necessary by going to Devices > Enrollment restrictions > Default and editing the device limit settings.
- Personal Device Enrollment: If your device is recognized as a personal device, ensure that personal device enrollment is allowed. You can adjust this setting in the Intune admin center under Devices > Enroll devices > Enrollment device platform restrictions.
- Sync the Device: After attempting to enroll, if you encounter issues, try syncing the device. This can sometimes resolve connectivity problems.
- Run Diagnostics: You can run self-help diagnostics in the Microsoft 365 admin center to identify any configuration issues that may be preventing enrollment.
- Check for Error Codes: If you receive any specific error codes during the enrollment process, look them up in the Intune troubleshooting documentation for targeted solutions.
If these steps do not resolve the issue, consider reaching out to your IT support team for further assistance.
