Restoration of backuped up sharepoint sites to original location using M365 backup using csv doesn't work
Madhuri Prakash Kamble 1 Reputation point
2026-01-09T15:42:52.25+00:00
Hi ,
I am trying to perform restoration of few deleted sites using csv to its original url option which are protected using M365 backup solution but facing issue
Error : There no site sites that match this url
Also, want to know will restoration to original url works if sites are in soft deleted state?
ThanksinAdvance
Microsoft 365 and Office | SharePoint | For education | Other
    2026-01-09T15:42:59.04+00:00
    When restoring SharePoint sites using the Microsoft 365 Backup solution, if you encounter the error "There are no sites that match this URL," it may indicate that the specified URL does not correspond to any existing sites in the backup or that the sites are in a state that prevents restoration to that URL.
    Regarding your question about restoring sites that are in a soft deleted state, it is important to note that SharePoint sites that are soft deleted can typically be restored. However, if the restoration is attempted to the original URL, it may not work if the site is still considered soft deleted. In such cases, it might be necessary to restore the site to a new URL first and then handle the data accordingly.
    For best practices, ensure that the URLs you are using in your CSV file are correct and that the sites are indeed in a state that allows for restoration. If issues persist, consider checking the specific conditions of the sites you are trying to restore.
    2026-01-09T18:49:47.06+00:00
    Hi @Madhuri Prakash Kamble
    Welcome to Microsoft Q&A forum.  Thank you for your questions. I understand how disruptive this issue may have caused.
    Regarding the error encountered during the CSV-based restore, stating that there are no sites that match the specified URL, this usually means that Microsoft 365 cannot identify the target site URL as an active SharePoint site at the time the restore job runs. This commonly happens when the site is in a soft-deleted state. Soft-deleted sites are retained in the SharePoint admin center under Deleted sites, but they are not considered active, even though the URL is still reserved. Because of this, restore to original URL cannot be completed and the restore process returns this error. Other possible contributors include an incorrect URL format in the CSV file or the site being in a pending deletion state.
    For your second question, restoring to the original URL does not work while the site remains soft deleted. A restore to original URL requires the destination site to already exist and be active. While a soft-deleted site still holds its original URL, it is inactive and therefore cannot be used as a restore target.
    As a recommended alternative, you can first restore the deleted site directly from the SharePoint admin center by navigating to Deleted sites and restoring the site. Once the site is active again, the original URL becomes available and the CSV-based restore to the original URL can be retried successfully.
    I hope you found the answer helpful, and we would greatly appreciate it if you could mark it as accepted. This helps highlight the solution for others who may be searching for similar information in the community. Your contribution not only supports fellow users in finding the right guidance more quickly, but also helps build a more resourceful and collaborative space for everyone.
    Thank you for your kindness and contributions to the forum.
  3. Madhuri Prakash Kamble 1 Reputation point
    2026-01-12T07:22:58.22+00:00
    Hi Jay,
    Thanks for your response.
    From your response,we can understand that if any site is in soft deleted state, we won't be able to restore to its original url using M365 Backup solution as the site url is reserved.
    But when we try to restore the same single site by selecting manually, we are able to restore it to original url and only facing the issue when we are performing using CSV method.
    What can be the reason?
