A free app and service that helps families create healthy digital habits and stay connected. It’s designed to support both online safety and real-world awareness by offering tools for screen time management, content filtering, and location sharing
It seems you are experiencing issues with blocking unwanted senders in your MSN email account. Unfortunately, the context provided does not contain specific troubleshooting steps for MSN email accounts. However, you may want to consider the following general steps that could help:
- Check Spam Settings: Ensure that your spam settings are configured correctly. Sometimes, adjusting these settings can help with blocking unwanted senders.
- Use Outlook Blocked Senders: If you are using Outlook for your MSN email, you can add the sender to the Blocked Senders list in your Outlook settings. This action should block emails from that sender.
- Contact Microsoft Support: Since Norton suggested contacting Microsoft, reaching out to Microsoft Support directly may provide you with specific assistance tailored to your issue.
If the problem persists, it may be beneficial to check for any updates or changes in your email settings or consider using the Microsoft support resources for further assistance.
