Other issues or features related to Microsoft Edge on older Windows versions
Im not sure what happened but when i finished charging my chromebook,
this suddenly appeared. I haven’t updated it in a while, so maybe it was because of that. I resetted it, and even rebooted it but it still has the pixels! I don’t know what to do. Help! The pixels are green, and are vibrating!! (It wont let me post a pic of the laptop)
AI answer
It sounds like you are experiencing a display issue with your Chromebook, specifically with green vibrating pixels. Here are a few troubleshooting steps you can try:
If the problem continues after trying these steps, it may be a hardware issue, and you might need to contact support or consider professional repair.
Your image indicates a problem with the graphics drivers most likely.
Start your laptop, just as Windows attempts to load (spinning dots), press and hold Power Button for 5 - 10 seconds to perform a Hard Shut Down
Do this twice
On the third start Windows will boot into the Recovery Environment and from there you can access System Repair, Safe Mode, Command Prompt... etc.
Go to Troubleshoot - Advanced Option - Startup Settings and click Restart
Upon restart, press 5 to enter Safe Mode
Once in Safe Mode, open Device Manager, expand the Display Adapters section, and uninstall the graphics drivers.
Then, restart your laptop to check if Windows has installed a new graphics driver and if that resolves the problem.
