Edge Mobile won't sign me in.
Anshrr 0 Reputation points
2025-12-27T02:18:50.7866667+00:00
Hello. Edge on my Samsung Flip7 FE is bugged somehow, and won't let me sign in to synchronize bookmarks etc. When I try with a passkey, it gives me and error (Something went wrong. [9n155] *), if I try without a passkey, it claims I've tried, and used the wrong password, too many times, makes me enter password and a text Captcha that does not work.
Trying to log into Microsofts website in Edge, doesn't work either, get the wrong password thing.
This wasn't a problem last week, but when I was trying to enter some credit card details stored in my account, it wanted me to verify my account. That's when it started.
What I've tried;
  • Using same passkey to log into Outlook, works.
  • Using passkey to log into website via Chrome and Samsung's webbrowser, works.
  • Logging in normally on PC, works.
  • Log into Edge on my partners Samsung phone, via "passkey on different device" (which is same device that can't log into it's Edge), works.
  • Verify account in Edge on Samsung tablet, worked.
  • Change password, still get the same errors.
  • Reset/empty app files/cache, did nothing.
  • Uninstall/reinstall Edge on phone, did nothing.
  • Remove Passkey, re-add passkey, nothing works.
So, tl;dr, the only place I can't log in to my MS account, is in Edge on my Samsung phone.
I can only assume there's something wrong with Edge files on the phone, but uninstalling didn't fix it, so I am at a loss. I don't particularly feel like resetting my entire phone to fix this, and am currently making do with Samsung's browser.
Has anyone experienced something like this, and/or have a solution?
Thanks!
  • The error message beneath the error is as follows:
Correlation Id: [Moderator note: PII removed]
Timestamp: 2025-12-26T14:25:32.000Z
DPTI: [Moderator note: PII removed]
Message: Access denied for the resource.
Tag: 9n155
Code: 0
Microsoft Edge | Browser crashes or stops working | Android
    2025-12-28T06:11:01.0366667+00:00
    Hi Anshrr,
    Thanks for reaching out to Microsoft Q&A Forum. I understand you're facing error tag 9n155. Please try to clear Edge profile data (not just cache). Go to Settings > Apps > Edge > Storage and clear
    • Site settings
    • Cookies and site data
    • Saved form data
    Then try login again.
    The initial response might not address the problem. So, if your problem persists or you need any assistance, feel free to ask me by clicking "Add Comment" or "Post Answer" if you cannot add comment. This helps me can read your follow up. Thanks for your effort.
    Please note that our forum is a public platform, and we will modify your question to hide your personal information in the description. Kindly ensure that you hide any personal or organizational information the next time you post an error or other details to protect personal data.
