Teams Channel Shortcut explorer Paths
Tonny Dithobane 0 Reputation points
2025-12-26T22:42:38.3533333+00:00
Happy holidays,
My team and I rely heavily on Microsoft Teams channels to collaborate on our projects, and the “Add shortcut to OneDrive” feature has been an essential part of our workflow. It allows us to sync channel files to our computers and has significantly improved our collaboration.
However, we’ve recently noticed an issue with shortcuts created from private channels. When these shortcuts sync to File Explorer, the folder path contains duplicated text, which significantly increases the character length of the path. This becomes a problem for some of our scripts and applications that cannot handle long paths.
For example:
[Moderator's note: PII removed]
(Notice the repeated section in the path name.)
This duplication does not occur when shortcuts are created from standard (non-private) channels.
Could you please advise whether this behavior is expected, and if there is a workaround or configuration change that can prevent the duplication?
Thank you for your help.
Microsoft Teams | Microsoft Teams for business | Teams and channels | Private channels
    2025-12-27T01:20:12.7233333+00:00
    Dear @Tonny Dithobane,
    Happy holidays! Thank you for reaching out to the Microsoft Q&A forum. I’m happy to assist.
    I attempted to reproduce the issue by creating a private team, adding a channel, and placing a .docx file in that channel. I then opened the channel’s folder in SharePoint and used Add shortcut to OneDrive. I also tested creating a shortcut to the individual .docx file. In my environment, the duplication did not appear.
    The path to the file appears as:
    C:\Users\[user name]\OneDrive - [company]\test.docx.url
    The path to the folder appears as:
    C:\Users\[user name]\OneDrive - [company]\test shortcut - test 1
    Below is the screenshot of File Explorer after syncing OneDrive.User's image
    To investigate further and provide accurate guidance, could you please confirm the following details? Which object did you click “Add shortcut to OneDrive” on?
    The folder (e.g., …\Documents<folder>)
    The library (Documents)
    Or the file (e.g., Locations.docx)
    (Note: Adding a file creates a .url web shortcut, while adding a folder or library creates a real folder in OneDrive.)
    Could you please confirm whether the steps you used to add the shortcut are the same as the process I described above, or if they differ in any way?
    A brief step-by-step description will help us reproduce the exact behavior.
    Does the issue occur for all users, all files/folders, or only for specific users or specific folders?
    If possible, please provide a screenshot showing the complete shortcut path as it appears in File Explorer and in SharePoint/OneDrive. This will allow us to identify whether the duplication is caused by similar site and folder names or by a different issue.
    Please send the screenshot through a private message if it contains any personal information.
    Also, your thread included personally identifiable information (PII). To protect your privacy, I’ve hidden it from the public thread and sent it to you via private message. If you need to share any further PII, please do so in that private message.
    Here's how you can access your private messages:
    1. Go to a question you asked that has a private message.
    2. Open private messages modal – by clicking link in blue banner or private messages button.
    3. User's image
    4. Private messages modal opens
    5. Enter reply into rich-text editor.
    6. Click "Send" button
    Providing these details will enable us to offer the most accurate next steps and, if necessary, route your request to the appropriate team for further assistance. Looking forward to your response so we can assist you further!
  2. AI answer
    2025-12-26T22:42:47.5866667+00:00
    The behavior you're experiencing with duplicated text in the folder path when syncing shortcuts from private channels in Microsoft Teams is not documented in the provided context. However, it is important to note that the OneDrive sync app and its interaction with Teams channels, particularly private channels, can sometimes lead to unexpected results due to the way paths are constructed and managed.
    As for workarounds, while the context does not specify any, you might consider the following general approaches:
    1. Rename the Shortcut: If possible, manually rename the shortcut after it has been created to avoid the duplication in the path.
    2. Use Standard Channels: If the duplication is causing significant issues, consider using standard channels for projects where this is a concern, as you mentioned that the duplication does not occur there.
    3. Script Adjustments: If your scripts can be modified, consider adding logic to handle or truncate long paths to avoid errors.
    For more specific solutions or updates regarding this issue, it may be beneficial to reach out to Microsoft support or check for updates in the Teams or OneDrive documentation.
