Hi David,
Thanks for reaching out to Microsoft Q&A Forum. I understand how frustrating repeated Phone Link disconnects can be. Based on the details you shared, please follow these steps:
1, Reset the Bluetooth + Wi‑Fi Link Layer
Phone Link depends on both:
- Wi‑Fi (primary data channel)
- Bluetooth (control channel)
To refresh both sides cleanly:
On Windows
- Settings > Bluetooth & devices > Devices > Remove your phone
- Settings > Network & Internet > Advanced network settings > Reset network adapters (Wi‑Fi + PAN)
On Samsung
- Settings > Connections > More connection settings > Reset mobile network settings
- Toggle Nearby device scanning ON (Samsung requirement for stable Link to Windows)
2, Disable Samsung Battery Restrictions on “Link to Windows”
Open Android settings > Apps > Link to Windows > Battery > set to Unrestricted Also turn off:
- “Pause app activity if unused”
- “Adaptive battery” (optional but helpful)
3, Re‑pair Using the Modern Connection Flow
On the phone:
- Open Link to Windows > Menu > Re‑link with PC
On Windows:
- Open Phone Link > Settings > My Devices > Unlink this PC > Sign in and re‑pair
The initial response might not address the problem. So, if your problem persists or you need any assistance, feel free to ask me by clicking "Add Comment" or "Post Answer" if you cannot add comment. This helps me can read your follow up. Thanks for your effort.
