How to enable secure boot and tpm 2.0 on American Megatrends 2012 version.
indy grimaldi 25 Reputation points
2025-12-24T13:15:07.8366667+00:00
To play Call of Duty Warzone I need to enable secure boot and tpm 2.0, but all tutorials have a different version of my BIOS. Please Help.
Moved from: Community Center | Discuss the Q&A site | Get started on Q&A
Airbus A350 7,770 Reputation points Volunteer Moderator
2025-12-24T13:51:27.5133333+00:00
If you open the Start Menu, look for the power button in the bottom right-hand corner, push it; and while holding down the Shift key, push "Restart". You should see a screen that says "Please wait" if executed properly.
Once your PC restarts, you should see a screen that gives you a few options; out of those few options should be an option that says "Troubleshoot". Select that, and then push "Advanced options" and then finally "UEFI Firmware Settings".
Your PC should restart again, and you should now see the BIOS screen.
Look in the Boot or Security section (use the left/right arrows to navigate menus) and find options for the Secure Boot and TPM.
Once both of them are enabled, see if you can install Call of Duty.
If you need help at any of these sections, you can also take pictures and upload them here and I can help you like that as well.
Let me know how this goes.
1 additional answer
  1. Ростислав Мишунин 0 Reputation points
    2026-07-31T10:42:28.8866667+00:00
    У меня похожая проблема нет этой кнопки и функции. У нас на наших российских форумах пишут что если плата от Intel Xeon то на ней может и не быть этой функции, это какая-то китайская неочень хорошая вещь. Так что наверное лучше будет поменять её или изменить наверное
