An Azure managed PostgreSQL database service for app development and deployment.
Hey Matthew Y,
It sounds like you're facing quite a hassle with your PostgreSQL database being stuck in the "Starting" state. Here are some steps you can take to try and resolve this issue:
- Check Current Status: Start by checking the status of your PostgreSQL server via the Azure Portal. Sometimes it might just be a temporary glitch.
- Force Stop through Azure CLI: If you're unable to stop it from the Azure Portal, you can attempt to forcefully stop it using the Azure CLI. Here's the command:
Make sure to replace `<YourServerName>` and `<YourResourceGroupName>` with your actual server and resource group names. -
- Restart the Instance: If stopping isn't working, you might want to restart the entire PostgreSQL server. Again, you can do this via Azure CLI:
az postgres server restart --name <YourServerName> --resource-group <YourResourceGroupName> - Check Logs: After trying to stop or restart the server, check the server logs in the Azure Portal under the "Logs" section. This could give you more insight into why the server is stuck.
Update on 26/12/2025:
We connected with you via Teams chat, and our product team successfully moved the server to a Succeeded state. You have also confirmed that you are able to see the server now.
I hope this helps.
Your feedback is important so please take a moment to accept answers. If you still have questions, please let us know what is needed in the comments so the question can be answered.
Thanks!
Kalyani
