A Microsoft hybrid cloud storage solution that combines on premise hardware storage and cloud storage.
Hi @Shofi ,
DFS only creates the links, so to migrate the actual data you have a few options, personally I would recommend robocopy.
Use robocopy or any other equivalent tool to copy your data from your StorSimple volumes to your new volumes, if the new volumes are attached to your existing DFS servers and the drive letters are the same then you won't need to do anything within DFS itself.
The drive letters may be different during the copying, but once you have all data copied from the StorSimple, set those volumes offline, and assign the same drive letter to your new volumes and you should have everything working again.
If the reply was helpful please don't forget to upvote and/or accept as answer, thank you!
Best regards,
Leon
