How do I change the battery icon to display power percentage in number form at all times on the task bar.
j aftergood 20 Reputation points
2025-12-18T17:55:35.85+00:00
I have searched the settings for a while.. looked up many guides and cannot locate where I set the battery display on the task bar to show me the exact battery's power precentage at all times. I simply want to be able to glance at the icon and see the exact precentage displayed without scrolling over or prompt.
While in the Power @ Battery settings, there is no button or selection for this even though the Microsoft online guide tells me there should be.
Again, i am looking for the battery icon to display power percentage in number form at all times on the task bar.
Please advise.
AI answer
2025-12-18T18:00:07.33+00:00
To display the exact battery percentage in number form on the taskbar in Windows 11, follow these steps:
  1. Right-click on the Taskbar: This will open a context menu.
  2. Select Taskbar settings: This option will take you to the taskbar customization settings.
  3. Scroll down to the Notification area: Look for the section that manages system icons.
  4. Click on Turn system icons on or off: Here, you can manage which icons appear in the notification area.
  5. Ensure the Power icon is turned on: This will allow the battery icon to show up on your taskbar.
  6. Go to Settings: You can do this by clicking on the Start menu and selecting the gear icon or by pressing Windows + I.
  7. Navigate to System > Power & battery: In this section, you can manage your power settings.
  8. Check for Battery Percentage: Ensure that the option to show battery percentage is enabled. However, note that Windows 11 does not provide an option to display the battery percentage directly on the taskbar icon at all times.
If you want the battery percentage to be visible at all times, you may need to consider using third-party applications that can provide this functionality, as the built-in settings do not currently support this feature.
Additionally, ensure that your Windows is up to date, as updates can sometimes add new features or settings that may help with your request.
1 additional answer
  1. roberooski 0 Reputation points
    2026-09-14T06:01:24.95+00:00
    I am very disappointed that Microsoft did not include numbered percentages on the battery charging icon in the task bar with Windows 11
