How do I add a drop down menu function to cells in a table in word?
Brian McIver 0 Reputation points
2025-12-18T01:34:05.93+00:00
I'm creating a new word template. There is a table in it where rows are numbered, and relate to one of a small list of categories. I'd like to format the second column as a drop down menu for ease of use.
Any guidance?
Microsoft 365 and Office | Word | For business | Windows
Jay Freedman 208.3K Reputation points Volunteer Moderator
2025-12-18T02:09:41.8866667+00:00
Insert a Dropdown List Content Control in each cell of the column and add the list of categories to it.
  • If you don't have the Developer tab displayed in your copy of desktop Word, go to File > Options > Customize Ribbon and add it.
  • Click in the first cell of the column.
  • On the Developer tab, click the Drop-Down List Content Control button to insert a control in the cell.
1
  • Enter a title for the control (this will appear above the control when it's selected) and/or a Tag value (this is invisible to the user but can be used by macros to access the control).
2
  • If you don't want users to be able to enter a category that doesn't appear in the list, check the box for "Contents cannot be edited".
  • Click the Add button and enter a display name (this will appear in the dropdown). The Value box will default to the same text as the display name, but you can change it if you want -- the value will be accessible to macros for calculations if necessary. Repeat this step for each additional category.
  • When the list is complete, click OK.
  • If the lists in all the cells of the column should be the same, you can copy the first one and paste it into the other cells; or you can supply a different list for some or all of the other cells.
1 additional answer
  1. John Korchok 236K Reputation points Volunteer Moderator
    2025-12-18T02:09:52.7666667+00:00
    You can add a Drop Down List Content Control from the Developer tab of the Ribbon.
    If the Developer tab is not visible, choose File>Options>Customize Ribbon, then check Developer in the right-hand list of Main Tabs. OK out and it will appear.
    Here is Microsoft's page on Content Controls with more information about how to use them: Content controls in Word
