KB5051974 broke Start Menu — UI regression needs urgent fix
Arfan Alam 0 Reputation points
2025-12-15T01:32:45.39+00:00
Hey Mirco, After installing K8505, the new start menu with the tabs and the buttons feels uncomfortable and visually broken. The background turned into a solid dark block and its affecting usability. I'm sure many users dislike this change too
Please add an "are you sure" prompt before installing updates, Clearly list the changes they do
My poor kirby is stuck behind a glass - please fix this UI regression in the next updates BTW, I appreciate the work you all do to make our feedback come true! Copillot helped me write this (expect for the make our feedback come true part) Thanks goodbye
Windows for home | Windows 10 | Desktop, Start, and personalization | Start Menu
  1. Huy-K 13,985 Reputation points Microsoft External Staff Moderator
    2025-12-16T01:15:23.1166667+00:00
    Dear @Arfan Alam,
    Thank you for posting your question in the Microsoft Q&A forum.
    We apologize for any inconvenience you may encounter when using our services/ products. Based on your description, kindly try these following steps:
    System file repair
    • Navigate to Command Prompt (Run as Administrator) > type:
    sfc /scannow
    DISM /Online /Cleanup-Image /RestoreHealth
    • Restart when complete.
    If the answer is helpful, please click "Accept Answer" and kindly upvote it. If you have extra questions about this answer, please click "Comment".
    Note: Please follow the steps in our documentation to enable e-mail notifications if you want to receive the related email notification for this thread.
