A family of Microsoft presentation graphics products that offer tools for creating presentations and adding graphic effects like multimedia objects and special effects with text.
If your Bluetooth device (Buds Pro) is connecting but not receiving audio, here are some troubleshooting steps you can follow:
- Check Bluetooth Settings: Ensure that Bluetooth is turned on in your device settings.
- Device Compatibility: Verify that your Bluetooth device is compatible with your system. Some devices may not support certain audio profiles.
- Restart Devices: Restart both your Bluetooth device and the device it is connected to, as this can sometimes resolve connectivity issues.
- Audio Output Settings: Make sure that the audio output is set to your Bluetooth device. You can check this in the sound settings of your device.
- Driver Updates: Ensure that your Bluetooth drivers are up to date. You can check for updates in the Device Manager.
- Reconnect the Device: Remove the Bluetooth device from your paired devices list and then reconnect it.
- Check for Interference: Ensure there are no other Bluetooth devices interfering with the connection.
If the issue persists, it may be helpful to check for any known issues related to Bluetooth audio devices in the documentation for your operating system or device.
