device missing important security and quality issues
john Raams 5 Reputation points
2025-12-11T01:38:11.47+00:00
I am receiving the above subject line message on my laptop.. I have run the troubleshooter and also the windows assistant. I am still getting the same message. I have signed on for extended support
abbodi86 5,101 Reputation points
2025-12-11T19:47:56.61+00:00
Ignore all above generic non working suggestions
download this and rename to WaaS-reset.reg (remove .txt extension), then double click to merge
https://pastebin.com/RuZnFXS1
4 additional answers
    2025-12-11T01:38:24.8133333+00:00
    If you are receiving a message indicating that your device is missing important security and quality updates, and you've already run the troubleshooter and Windows Assistant without resolution, consider the following steps:
    1. Check Windows Update Settings: Ensure that your Windows Update settings are configured to automatically download and install updates. Go to Settings > Update & Security > Windows Update and check for updates manually.
    2. Run the Windows Update Troubleshooter: Sometimes, running the built-in Windows Update troubleshooter can help resolve issues. You can find it in Settings > Update & Security > Troubleshoot > Additional troubleshooters > Windows Update.
    3. Check for Corrupt Files: Use the System File Checker (SFC) tool to scan for and repair corrupted system files. Open Command Prompt as an administrator and run the command sfc /scannow.
    4. In-Place Upgrade: If the problem persists, consider performing an in-place upgrade of Windows. This process reinstalls Windows without affecting your files and applications, which can resolve underlying issues with the update system.
    5. Contact Microsoft Support: If none of the above steps work, it may be beneficial to contact Microsoft Support for further assistance, especially since you have signed up for extended support.
    Following these steps should help you address the issue with missing security and quality updates on your device.
  2. GsN5034 - IA 77,095 Reputation points Independent Advisor
    2025-12-11T02:38:50.4133333+00:00
    Hello, thank you for reaching out to Microsoft Q&A.
    May I please know if you have any third-party Antivirus software installed on your computer? If yes, uninstall it and check for Windows updates again.
    If you're still having issues, reset the Windows update components by running these commands one by one on a Command Prompt (Admin) window.
    net stop bits
    net stop wuauserv
    net stop cryptsvc
    ren %systemroot%\SoftwareDistribution SoftwareDistribution.old
    ren %systemroot%\System32\catroot2 catroot2.old
    net start bits
    net start wuauserv
    net start cryptsvc
    Once done, restart your computer and check for updates again. If the error occurs, run the System File Checker utility.
    DISM /Online /Cleanup-Image /RestoreHealth
    sfc /scannow
    If you're still having issues, use the Windows 10 MCT tool and check for updates.
    https://go.microsoft.com/fwlink/?LinkId=2265055
    Run the Media Creation tool, click Upgrade this PC now, and click Next.
    Let me know if you still need more help.
  3. Kapil Arya 38,471 Reputation points Volunteer Moderator
    2025-12-11T04:53:38.3633333+00:00
    I highly recommend you to upgrade to the latest version to resolve this problem.
    You can try manual upgrade using Windows 11 25H2 ISO file.
    Follow these steps:
    Download Windows 11 25H2 ISO from the official Microsoft website.
    Double click on it to mount it to a DVD drive.
    Then go to DVD drive, double click on setup.exe to proceed.
    Follow on-screen instructions to complete upgrade.
    For detailed instructions, refer this step-by-step guide:
    https://www.kapilarya.com/how-to-upgrade-to-windows-11-version-25h2#method-3-upgrade-to-windows-11-25h2-using-iso-file
    Let us know if this helps!
    Note: Included link(s) in this reply refers to a non-Microsoft website. The page appears to be providing accurate, safe information. Watch out for ads on the site that may advertise products frequently classified as a PUP (Potentially Unwanted Products). Thoroughly research any product advertised on the site before you decide to download and install it.
  4. Charlie Dude 0 Reputation points
    2025-12-19T04:29:30.9666667+00:00
    Abbodi86 has the correct answer. I tried all the other answers that were given multiple times and none of them got rid of the message. They did get the updates installed, but didn't clear the error message.
