My surface laptop studio keyboard does not always react when pushing buttons for letters u, s, h, n. This is annoying (with all my love to surface).
Molkov, Vladimir 0 Reputation points
2025-12-09T13:07:42.3033333+00:00
Sometimes it works, but more often it does not work. I need multiple corrections of typed text.
Surface | Surface Studio | Performance and maintenance
    2025-12-09T13:07:50.6633333+00:00
    It sounds like you're experiencing intermittent issues with your Surface Laptop Studio keyboard, particularly with the keys for the letters u, s, h, and n. Here are some troubleshooting steps you can try:
    1. Update Drivers: Ensure that your keyboard drivers are up to date. You can check for updates in Settings > Windows Update.
    2. Check for Hardware Issues: If the problem persists, it may be a hardware issue. Consider cleaning the keyboard to remove any debris that might be affecting key responsiveness.
    3. Test in Safe Mode: Boot your device in Safe Mode to see if the issue persists. This can help determine if a third-party application is causing the problem.
    4. Feedback Submission: If the issue continues, you can submit feedback through the Windows Feedback Hub under the category Input and language > Keyboard. Include details about the specific keys that are not working as expected.
    5. Contact Support: If none of the above solutions work, you may want to reach out to Microsoft Support for further assistance.
    These steps should help you diagnose and potentially resolve the keyboard issue on your Surface Laptop Studio.
