Opening and reading PDF files in Microsoft Edge on Windows 10
Dear Microsoft, until now we were able to use the Edge pdf reader to correct the homework submitted by students. Now, if we write on the document, the file size increases significantly, making the work impossible. What can be done to make saving work as before, without any significant increase in size?
Best regards
Király Katalin
AI answer
The issue of increased file size when writing on PDFs in Microsoft Edge may be related to how the built-in PDF reader handles annotations and saved changes. Unfortunately, the current documentation does not provide specific solutions to reduce the file size when saving annotated PDFs. However, here are a few general suggestions that might help:
If the problem persists, exploring other PDF readers that allow for more efficient saving of annotated documents might be necessary.
