Incorrect Topology for Spain region in Network Watcher
Raja Sheker Vuttham (LTIMINDTREE LIMITED) 40 Reputation points Microsoft External Staff
2025-12-04T18:37:22.1066667+00:00
I am facing an issue with the network watcher topology.
For Spain Central: This region is being pinned out of the maps when as seen in the network topology viewer in the Network Watcher.
I have checked Israel Central, Italy North and Poland Central which are the new one's are found no issues with them. But for Spain Central it's showing out of maps.
There is no operation effect due to this but still curious to know the reason on this kind of behavior.??
Can someone please revert to the query.
Thank you in advance :-)
Raja
Azure Network Watcher
An Azure service that is used to monitor, diagnose, and gain insights into network performance and health.
Vallepu Venkateswarlu 10,590 Reputation points Microsoft External Staff Moderator
2025-12-16T15:19:22.3533333+00:00
Hi @ Raja Sheker Vuttham,
Welcome to Microsoft Q&A Platform.
This looks like a map rendering issue in the Topology UI for Spain Central. The positive aspect is that this issue does not affect your network operations, connectivity, or diagnostics—the underlying topology data remains accurate and complete.
The Topology view is powered by Azure Resource Graph. After configuration changes, the visualization can take up to 30 hours to refresh. During that time, and especially with newly added regions, pins may appear in the wrong place even though the actual resources and relationships are fine.
Please "Accept the answer" if the information helped you. This will help us and others in the community as well.
1 additional answer
    2025-12-04T19:37:07.02+00:00
    Hello @Raja Sheker,
    Thank you for reaching out & hope you are doing well.
    I understand your question regarding why a region appears to be pinned outside of the maps when viewed in the network topology viewer in Network Watcher.
    We’ve checked the behavior you’re seeing in Network Watcher → Topology for Spain Central, and here’s what we found:
    This looks like a map rendering issue in the Topology UI for Spain Central. The good news is that it doesn’t impact your network operations, connectivity, or diagnostics—the underlying topology data is correct and intact.
    Why this happens
    What you can do
    • Check your scope and filters: Make sure the Topology scope includes your subscription/resource groups and Spain Central, then reapply.
    • Try alternate views while the UI refreshes: • Monitor → Insights → Networks → Topology (same data, different entry point) • Virtual network → Monitoring → Diagram for a per‑VNet view • Use Download topology to export an accurate diagram for documentation
    • Confirm Network Watcher is enabled in Spain Central for your subscription. If it’s not, you can enable it through the Azure portal or CLI.
    If the issue persists:
    If the pin still looks off after the refresh period, please share a screenshot and provide requested information in private message.
    I have posted the same information as the answer. Please Accept the answer if the information helped you. This will help us and others in the community as well.
