seems my issues were largely due to a failed store migration during the upgrade from 24H2 to 25H2. this was due to a rare bug during the upgrade process. I have since fixed hat issue as well as all the other issues that cropped up and compounded as a result of the migration failure. I give big props to the people at the CoPilot team. Copilot was able to not only correctly diagnose the issue but, also permanently fix the issue. the migration failure was something that could not be fixed by simply doing a repair install, as the migration ONLY occurs during the upgrade from 24H2 to 25H2. since that upgrade had already occurred, the issue was unresolvable by normal methods. But CoPilot was able to guide me through it all and now my system runs much better. And all the various updates are installing without any issues.
strange issues after performing system cleaning
a week or two ago i performed some system maintence on my system, which i had not done lately. this mainly consisted of cleaning out temporary files and so on. I DID NOT use any weird or third party tool or utilities. i used only what was included with windows and the Microsoft PC Manager app. everything went well, but the windows shell start acting wonky after i used the disk cleanup app. i restarted, and found the start menu, widgets panel and taskbar had reverted to their un-updated state. i of course ran sfc and dism, but no errors were found. i eventually ended up using the vivetool to turn that stuff back on. but following that, Windows started trying to either do a repair install or just download the 25h2 update (im not sure which is the case). if windows wanted to repair itself, then that's fine, great even. the problem is that the download via windows update titled 'Windows 11, 25H2' keeps failing. However, all other updates are successfully getting installed. this includes the LCU updates. i tried to initiate a repair using windows update using 'settings>system>recovery' but the option 'fix problems using windows updates' is greyed out and says 'this option is currently unavailable'. there are times that the download seems to successfully complete in windows updates, but following a restart, it just tries to download the same thing all over again. in the last few days the update has been erroring out, with several different error codes. the last two error codes were '0x80070057' and '0x800706ba'. since other updates seem to be able to install, i don't think this is a normal os corruption issue. especially with the way the issue was triggered.
i am not sure how to proceed to clear the issue i am currently having. advice other than using the windows update troubleshooter (you can't its broken for everyone om windows 11) or doing a clean install would be most helpful. i could do a repair install using an .iso, i suppose, but my main concern is that that will just return my system to the state it was before i did my maintenance, and the next time i do maintenance, i will just end up in the same situation as i am in now.
Windows Insider program | Windows Insider preview | Performance and maintenance
CrazyKats 19,245 Reputation points Volunteer Moderator2025-12-09T23:23:50.4833333+00:00 Hi,
Just out today for Patch Tues. is 26200.7462.
I hope you have better luck with that update.
CrazyKats 19,245 Reputation points Volunteer Moderator2025-12-04T03:21:45.0566667+00:00 Hi,
Exactly what build are you on?
Use WIN+R, type winver for the build #.
Is your PC Widows 11 compatible?
Run: https://aka.ms/GetPCHealthCheckApp
It sounds like a clean install would be your
best bet.
Will await your reply.
