Quickbooks tells me I need to uninstall and reinstall microsoft
Lisa Groce 0 Reputation points
2025-12-04T00:31:17.1066667+00:00
My Quickbooks desktop is not operating properly. The agent there said I need to uninstall Microsoft and reinstall to fix the problem
Surface | Surface Duo | Install and update
    2025-12-04T00:31:25.48+00:00
    To uninstall Microsoft Office, you can follow these general steps:
    1. Restart your computer: Sometimes, a simple restart can resolve issues that prevent uninstallation.
    2. Use the Control Panel: Go to Control Panel > Programs > Programs and Features. Find Microsoft Office in the list, select it, and click on Uninstall.
    3. Use the Microsoft Support and Recovery Assistant: If you encounter issues during uninstallation, you can download and run the Microsoft Support and Recovery Assistant tool to help remove Office.
    4. Follow the manual uninstall steps: If the above methods do not work, you can follow the manual uninstall steps provided by Microsoft.
    After uninstalling, you can then proceed to reinstall Microsoft Office to resolve any issues with QuickBooks.
    If you continue to experience problems, consider checking for any updates or compatibility issues between QuickBooks and the version of Microsoft Office you are using.
