How to get more Xbox home switches
Max mena 20 Reputation points
2025-11-30T04:07:58.89+00:00
I’ve been having a problem with Xbox home switching a random account in another state logged into my account and may have used some switches and I also switched to my own Xbox and it was switched back to theirs I need one more to get it onto mine;
Moved from: Microsoft Security | Microsoft Authenticator
Windows for home | Other | Input and language
    2025-11-30T04:08:04.2966667+00:00
    To manage Xbox home console switches, you need to be aware of the limitations imposed by Microsoft. Each Xbox account can only switch its home console a limited number of times within a year. If someone else has switched your home console to their account, you may need to wait until the switch limit resets or contact Xbox Support for assistance.
    Here are some steps you can take:
    1. Check Your Account Settings: Ensure that your account is set as the home console for your Xbox. You can do this through the settings on your console.
    2. Remove Unauthorized Devices: If you suspect that someone else is using your account, change your password and sign out of all devices to prevent unauthorized access.
    3. Contact Support: If you are unable to switch your home console due to limits, reach out to Xbox Support for help. They can provide guidance based on your specific situation.
    Remember, you can only switch your home console a limited number of times, so it's essential to manage your switches carefully.
  2. Vikki-T 10,375 Reputation points Microsoft External Staff Moderator
    2025-12-02T07:46:47.42+00:00
    Dear Max mena
    Thank you for contacting to Q&A Forum. I understand how frustrating it can be when your Home Xbox settings change unexpectedly, and I truly appreciate your patience while we work through this together.
    I’d like to start by letting you know that Microsoft allows only five Home Xbox switches per year (How home Xbox and game sharing work | Xbox Support). Unfortunately, additional switches cannot be purchased. If your switches were used without your consent, this may indicate that your account has been compromised, and we strongly recommend securing it immediately.
    Although AI may have already mentioned some of these steps above, I’d like to provide a more detailed guide to help you resolve this issue effectively.
    Here’s what you should do:
    1. Secure Your Account
    1. Verify Your Home Xbox Settings
    • On your console, go to Settings > General > Personalization > My Home Xbox to confirm your current setup.
    1. If You’ve Reached Your Switch Limit
    • Contact Xbox Support directly. Explain that your account was accessed without permission and your switches were used. In some cases, they may assist with resetting your limit.
    Contact Xbox Support:
    • Visit Xbox Support
    • Sign in with your Microsoft account and select Contact Us for personalized help.
    We understand this situation can be frustrating, and we’re here to support you every step of the way. Please complete the security steps first to prevent any further unauthorized changes.
    If you have any other questions or need additional assistance, don’t hesitate to reach out.
    Note: Please follow the steps in our documentation to enable e-mail notifications if you want to receive the related email notification for this thread.
  3. Deleted
  4. alex klepek 5 Reputation points
    2026-05-30T07:54:41.48+00:00
    J'ai besoin de 1 switch car on m'a piraté et j'ai réussi à changer le MDP mais faut remettre le compte à mon domicile mais plus de possibilité
  5. Ronaldoisthegoat grimes 0 Reputation points
    2026-06-25T00:31:40.9233333+00:00
    This has very helpful thank you 😁
