How to get more Xbox home switches
Max mena 20 Reputation points
2025-11-30T04:07:58.89+00:00
I’ve been having a problem with Xbox home switching a random account in another state logged into my account and may have used some switches and I also switched to my own Xbox and it was switched back to theirs I need one more to get it onto mine;
Moved from: Microsoft Security | Microsoft Authenticator
Windows for home | Other | Input and language
    2025-11-30T04:08:04.2966667+00:00
    To manage Xbox home console switches, you need to be aware of the limitations imposed by Microsoft. Each Xbox account can only switch its home console a limited number of times within a year. If someone else has switched your home console to their account, you may need to wait until the switch limit resets or contact Xbox Support for assistance.
    Here are some steps you can take:
    1. Check Your Account Settings: Ensure that your account is set as the home console for your Xbox. You can do this through the settings on your console.
    2. Remove Unauthorized Devices: If you suspect that someone else is using your account, change your password and sign out of all devices to prevent unauthorized access.
    3. Contact Support: If you are unable to switch your home console due to limits, reach out to Xbox Support for help. They can provide guidance based on your specific situation.
    Remember, you can only switch your home console a limited number of times, so it's essential to manage your switches carefully.
