my status column is showing a red x and I do not know what that means
Jim Del Re 20 Reputation points
2025-11-29T20:29:25.6866667+00:00
I have a red x in the status column of my files in Home File Explorer and need to know why.
AI answer
2025-11-29T20:29:30.79+00:00
The red X in the status column of your files typically indicates that the file is invalid or that there is an issue with the content associated with it. In the context of software updates, for example, a red X can signify that the software update is in an active deployment, but the content (software update files) is not available. This could occur if the file was removed from the deployment package or if there was a replication issue with the deployment package to a child site.
To resolve this, you may need to check if the content is available on the distribution point or redistribute the content as necessary. If this is related to a specific application or file type, further investigation into that application may be required.
If you need more specific guidance, please provide additional context about the files and the environment you are working in.
1 additional answer
  1. EmilyS726 266.9K Reputation points Independent Advisor
    2025-11-29T21:49:04.8666667+00:00
    Hello
    The AI answer is actually incorrect.
    The red X means these are files in the OneDrive folders. You need to make sure your OneDrive desktop app is running and signed in so the sync is resumed, so the x would be gone.
