I need to recover microsoft edge. how do i do it?
Eric Elzea 25 Reputation points
2025-11-25T21:54:40.56+00:00
I accidentally deleted my microsoft edge app. Can I get it back?
Microsoft Edge | Open the browser | Windows 10
AI answer
2025-11-25T21:54:45.16+00:00
To recover Microsoft Edge after accidentally deleting the app, you can reinstall it. Here are the steps you can follow:
  1. Download Microsoft Edge: Go to the official Microsoft Edge download page from another browser or device.
  2. Install Microsoft Edge: Once the download is complete, run the installer and follow the prompts to install Microsoft Edge.
  3. Check for Updates: After installation, ensure that Microsoft Edge is updated to the latest version by going to Settings and more (ALT + F) > Settings > About Microsoft Edge.
If you need to roll back to a previous version of Microsoft Edge, you can follow the manual rollback process using an MSI file. This involves disabling updates, downloading the desired version, and running a specific command in the command prompt. However, this is more advanced and typically not necessary for a simple recovery.
1 additional answer
  1. Restee Miranda 14,100 Reputation points Independent Advisor
    2025-11-25T22:28:53.4866667+00:00
    Hello Eric,
    Thanks for reaching out. Yes, you can get Microsoft Edge back. Here are the easiest ways.
    Option 1: Microsoft Store Open the Microsoft Store app, search for “Microsoft Edge,” and click Install. Confirm any prompts, and it will reinstall automatically.
    Option 2: Official Website Go to Microsoft Edge download page. Scroll down to find Download for Windows and run the installer.
    Hope this helps.
    Regards,
    Rez
