When will Smart App Control be on for everyone?
Dennis5mile 70 Reputation points
2025-11-20T17:38:17.6333333+00:00
On Nov 7th it was announced that "Smart App Control" can now be turned on without having to do a clean install of windows. I'm still not seeing that option... Anyone able to do this yet?
https://blogs.windows.com/windows-insider/2025/11/07/announcing-windows-11-insider-preview-build-26220-7070-dev-beta-channels/#:~:text=%5BSmart%20App%20Control,Microsoft%20Support.
Dennis5mile
Windows Insider program | Apps on Insider preview
  1. CrazyKats 19,245 Reputation points Volunteer Moderator
    2025-11-20T17:42:59.5866667+00:00
    Hi Dennis,
    I don't have it yet either.
    Per the Blog it's a gradual rollout.
  2. CrazyKats 19,245 Reputation points Volunteer Moderator
    2025-11-27T18:07:09.7966667+00:00
    Hi Dennis,
    Mine is still set to Off even on the
    latest build.
  3. Drew - 810 Reputation points
    2026-02-21T08:15:09.62+00:00
    It is not even in Canary 29531
  4. Drew - 810 Reputation points
    2026-03-15T06:20:31.5166667+00:00
    MS/Windows has reneged or backtracked on this. It is staying Clean Installs only.
  5. Drew - 810 Reputation points
    2026-03-29T10:33:15.5233333+00:00
    Won't be much longer...
    This is, now, a CFR with March 26, 2026—KB5079391 (Optional Update). It will, also, be with April Patch Tuesday.
    From the KB5079391 blog...
    [Smart App Control] New! You can turn Smart App Control (SAC) on or off without needing a clean install. To make changes, go to Settings > Windows Security > App & Browser Control > Smart App Control settings. When turned on, SAC helps block untrusted or potentially harmful apps. To learn more, see App & Browser Control in the Windows Security App. This feature was previously disclosed in January 2026 (KB5074105) and is now beginning to roll out.
