Printing Issue After Updating Word 365 on iPad
Eloy Gonzalez 100 Reputation points
2025-11-17T22:54:34.8066667+00:00
After updating Word 365 App on my iPad Pro M4 running iPad OS 26, the print function in Word does not work. Today’s update also updated Excel 365 and print works on Excel as well as other apps on my iPad Pro M4. It seems that only Word’s print fails. The “print menu item” is available on Word 365, but it does nothing with selected.
Microsoft 365 and Office | Word | Other | iOS
Arlene D 36,225 Reputation points Independent Advisor
2025-11-18T02:09:58.86+00:00
That makes sense and is a good temporary solution. Since AirPrint works in other apps and you’ve reported the issue to Microsoft, the problem is likely with the recent Word update. Using PDF export or Pages to print is the supported workaround until Microsoft releases a fix. Keep an eye on Word updates in the App Store, as the fix should arrive in a future update.
6 additional answers
  1. Eloy Gonzalez 100 Reputation points
    2025-11-24T20:00:02.9+00:00
    Word updated again today and the printing issue was resolved with that update… So, it seems that the print problem the previous update created has been resolved with today’s (11/24/25) update of the iPad app. Thanks to all for your help!
  2. June Piscitelli 0 Reputation points
    2025-11-24T21:57:30.2033333+00:00
    Thanks to whoever said it is fixed. Delete and reload the app. It is working.
