How to fix Correlation Id: ca5b1d70-695e-4609-9b7d-ed09a68248d1 Timestamp: 2025-11-17T16:38:05.000Z DPTI: 0d8373787b9eecd63f8d37c81dcf6a10f627658722dc905f7fe97a76f6ea979e Message: Access denied for the resource. Tag: 49dvs Code: 0
Roberto Ramos 0 Reputation points
2025-11-17T16:42:38.1033333+00:00
First time trying to login to Teams for my work account, but keep getting this error.
Microsoft Teams | Microsoft Teams Free | Sign up and Sign in | Sign in
    2025-11-17T17:16:31.48+00:00
    Hi Roberto Ramos, first, the error “Access denied for the resource” with a Correlation ID usually means your account doesn’t have the right permissions or the sign-in process is blocked by conditional access policies. Second, confirm you’re using the correct work account and not a personal Microsoft account, then clear your browser or app cache and try signing in again. Third, check with your IT admin to ensure your account is licensed for Teams and that there are no restrictions like MFA or device compliance blocking access. Last, if you’re on a managed device, make sure it’s enrolled and compliant with your organization’s policies; otherwise, try logging in via Teams Web to verify if the issue is app-specific. If the problem persists, share the Correlation ID and timestamp with your admin they can trace the error in Azure AD logs.
    If this helps, please mark the answer as accepted so others can find it too.
    -Carl
  2. Deleted
  3. Deleted
