Processes in Microsoft 365 for setting up Office apps, redeeming product keys, and activating licenses.
To uninstall the Office 16 Click-to-Run Extensibility component, you can follow these steps:
- Open Control Panel: Click on the Start menu and select Control Panel.
- Go to Programs: Click on Programs and then select Uninstall a program.
- Find Office 16: Look for Microsoft Office 16 in the list of installed programs.
- Uninstall: Right-click on Microsoft Office 16 and select Uninstall. This should remove the Click-to-Run Extensibility component as well.
If you encounter issues with uninstalling or if remnants of the 32-bit version are preventing you from installing the 64-bit version, you may need to ensure that all previous versions of Office are completely uninstalled. Here’s how:
- Use the Office Uninstall Tool: Microsoft provides a tool to help remove Office installations completely. You can download it from the official Microsoft support site and follow the instructions to remove all Office components.
- Check for Remaining Components: After using the uninstall tool, check the Control Panel again to ensure no Office components remain. If any do, uninstall them manually.
- Restart Your Computer: After uninstalling, restart your computer to ensure all changes take effect.
Once all 32-bit components are removed, you should be able to install the 64-bit version of Office without issues.
