Edge delate code
Noel-Castiel Stutterheim 0 Reputation points
2025-11-15T17:58:41.9466667+00:00
My microsoft rewards code what i redeemed on edge doesn't work bc in the Emile were 2 sites one worng and the right site and i did the worng site and doesn't work and my hard work is gone
Microsoft Edge | Website issues | Android
    2025-11-15T17:58:52.9533333+00:00
    It sounds like you're experiencing an issue with a Microsoft Rewards code that you redeemed through Microsoft Edge. If you entered the wrong site when trying to redeem your code, it may not work as expected. Unfortunately, if the code was redeemed incorrectly, there may not be a way to recover the points or redeem them again.
    For future reference, ensure that you follow the correct link provided in the email to redeem your rewards. If you believe there has been an error or if you need further assistance, I recommend reaching out to Microsoft Rewards support for help with your specific situation.
