Help! I can't remove my account microsoft edge on mac.
Kobie Quevedo 0 Reputation points
2025-11-13T06:41:03.19+00:00
I attached a sample photo from a reddit post here.
I clicked the trash bin button but it keeps popping up without any way to delete them.
I tried going into keychain access and deleting the ones from Microsoft with keyworks "oneauth..." but it still keeps popping up.
It's getting frustrating. Please help me.
Microsoft Edge | Profile, sync, and sign in | MacOS
  1. Ian-Ng 14,145 Reputation points Microsoft External Staff Moderator
    2025-11-13T21:42:36.5666667+00:00
    Hi @Kobie Quevedo,
    Welcome to Microsoft Q&A forum.
    Based on your information, you're trying to remove a persistent Microsoft account from Edge on your MacBook. This issue is common because the account is saved in your Mac's Keychain, which shares it with other Microsoft apps like Office and Teams.
    To completely remove it, kindly follow these steps:
    1. Sign Out of All Microsoft Apps
    First, you must sign the account out of every other Microsoft application on your Mac.
    1. Open Microsoft Word, PowerPoint, OneDrive, or Teams
    2. Click the application name in the top menu bar (e.g., "Word").
    3. Click "Sign Out..." and confirm. This often signs you out of all Office apps at once.
    4. Make sure this is done for any app that still shows you as signed in with the unwanted account.
    2. Remove the Profile from Edge
    Now, remove the profile from Edge itself.
    1. In Edge, go to edge://settings/profiles
    2. Find the profile you want to remove.
    3. Click the ... (three-dots) icon next to it and select "Remove" (or click the trash bin icon).
    3. Thoroughly Clear Your macOS Keychain
    1. Completely quit Microsoft Edge (press Cmd + Q).
    2. Open the Keychain Access app (you can find this using Spotlight search: Cmd + Space).
    3. In the search bar in the top-right corner of the Keychain Access window, search for the following terms, one by one.
    4. For each term, find any entries related to the account you want to remove, right-click them, and select "Delete..."
    Search for these terms: Microsoft, Edge, Office, ADAL, com.microsoft
    Note: You may see many entries. Look for any that are "Microsoft Account" or "Microsoft Office" credentials. Deleting these is normal; it will just require you to sign back into your desired accounts later.
    4. Restart and Check
    After you have cleared the Keychain entries and removed the profile from Edge, restart your Mac (or at least restart Microsoft Edge).
    I hope this information is helpful. Please follow these steps and let me know if it works for you. If not, we can work together to resolve this.
    Thank you for your patience and your understanding. If you have any questions, please feel free to reach out.
    I'm looking forward to your reply
