Setting which tray of my Epson WF-3540 printer I want Word to print from in Windows 11
Frank Hanrahan 0 Reputation points
2025-11-05T00:48:30.9166667+00:00
Setting which tray of my Epson WF-3540 printer I want Word to print from in Windows 11. Currently it defaults to tray 1. That is supposed to be for envelopes, not 8.5 x 11 letter paper.
Windows 7 had a preference setting, easy. Not Windows 11. Any ideas?
Microsoft Teams | Microsoft Teams Free | Settings | Configure notifications
  1. Randy Baroja 20,775 Reputation points Independent Advisor
    2025-11-05T01:27:10.83+00:00
    You can try this, Frank: open Word, go to File > Print > Printer Properties (next to your Epson WF-3540 name), then under the Paper/Quality or Main tab, look for Paper Source or Tray Selection and choose Tray 2 for your letter paper. If Word doesn’t save that as the default, go to Control Panel > Devices and Printers > right-click your Epson printer > Printing Preferences, set Tray 2 as the default there, and click Apply. This tells Windows (and Word) to always print from that tray unless you override it for a specific job. Just curious, do you use both trays often, or is Tray 1 only for envelopes permanently?
    Kind regards,
