CDN Updated Despite Block On Updates
Wesley Trantham 0 Reputation points
2025-11-04T01:02:50.6066667+00:00
My CDN somehow updated files this morning and broke the website. We noticed Nov 3 around 8 AM Central.
I released changes to the blob storage the night before, which is when I saw all the messages that we cannot purge the CDN. After testing the content looked the same as it had and I left it at that.
I repushed the correct files to the blob storage in hopes it gets picked up, which so far it has not.
Is this expected? Are files updating even with the block that is in place?
Azure Content Delivery Network
    2025-11-06T03:46:40.1833333+00:00
    Hi Wesley Trantham,
    Good day, i hope you are doing well!
    Quick update — Azure has lifted the temporary block on configuration operations. All create, update, delete, WAF, and cache purge actions for Azure Front Door and Azure CDN profiles are now enabled again.
    If the profile still appears locked or pending migration, please retry the operation. It may take up to 45 minutes for configuration and propagation to complete for added safety, as noted in the Azure Front Door FAQ.
    Once propagation finishes, you should be able to proceed with migration finalization or further updates. If the issue persists beyond that window, please do let us know.
    i hope you should be able to perform all the actions.
    If you found the answer helpful, it would be great if you please mark it "Accept as answer". This will help others to find answers in Q&A.
    Harish.
