Ability to fix comments
Naomi Nosonovsky 8,906 Reputation points
2025-11-03T17:56:24.8233333+00:00
There is an ability to edit the question, but no ability to edit the comments. This would be quite helpful as well.
Community Center | Discuss the Q&A site | Site suggestion
Neil D 34,200 Reputation points Volunteer Moderator
2025-11-03T18:31:55.13+00:00
Do you mean if you edit a comment you want to discard it. ? In which case select to edit the comment and you can Save nd view the question or Cancel the edit.
0 additional answers
