Does Microsoft have a fix for the common issue with laptop keyboards not working after Windows 11 Updates
Patrick Richey 45 Reputation points
2025-10-31T19:23:39.99+00:00
I have had multiple laptops, multiple brands, having their keyboards stop working after doing Windows 11 Updates. So far, the only temporary fix I have found is to delete the Standard Keyboard Driver, reboot, then the keyboard will work again until the next shutdown. Then I have to repeat the process. Does anyone have a real and actual fix for this issue? I've been through dozens found with Google, none of them actually work though. I'm used to having issues in Windows and I can usually figure out a fix for them, but this one actually has me stumped! I've already updated the BIOS to the latest version, performed all the latest Windows Updates, Disabled the Filter Keys, Reinstalled the Keyboard Driver, Ran SFC and DISM, and some other things I found online. FYI, I can plug in an external USB Keyboard and it will work, even after shutting down and restarting. This has happened on HP, Dell, Lenovo, and ASUS laptops. The only common denominators I have found so far is Windows 11 and the Standard Keyboard Driver. Currently it is happening on one with a fresh install of Windows 11 Pro using the Standard 101/102-Key or Microsoft Natural PS/2 Keyboard for HP Hotkey
Support. I'm looking forward to receiving positive input on this issue.
Hendrix-V 18,605 Reputation points Microsoft External Staff Moderator
2025-11-01T02:27:55.2566667+00:00
Hi Patrick Richey,
Thank you for reaching out to the Microsoft Q&A Forum! You’ve already done a lot of the right troubleshooting steps, so let’s focus on what usually resolves this issue permanently.
The behavior you described (internal keyboard stops working after Windows 11 updates, works again only after uninstalling the Standard PS/2 driver, external USB keyboard always works) points to two common causes:
  • Fast Startup restoring a bad driver state after shutdown.
  • OEM hotkey filter drivers (from HP, Dell, Lenovo, ASUS) interfering with the keyboard class in Windows.
Here is my suggested solution on what you can do to fix it:
Disable Fast Startup
  • Go to Settings → System → Power → Additional power settings → Choose what the power buttons do → Change settings that are currently unavailable, then uncheck “Turn on fast startup” and save.
    • Or run this command in an Admin terminal: powercfg /h off
  • Then perform a full shutdown to test: shutdown /s /t 0
The initial response might not address the problem. So, if your problem persists or you need any assistance, feel free to ask me by clicking "Add Comment". Thanks for your effort.
If the answer is helpful, please click "Accept Answer" and kindly upvote it. If you have additional questions about this answer, please click "Comment".
16 additional answers
  1. Nigel Nelson 30 Reputation points
    2025-12-09T16:36:51.4+00:00
    Seems like Webroot caused my keyboard problem. I downloaded the latest version of Webroot, which has a fix for the keyboard problem. Version 9.0.42.42 - Keyboard is working fine at login and after...for now.
  2. Anthony 10 Reputation points
    2026-02-07T03:17:24.7966667+00:00
    The reported keyboard problem has finally been fixed on my Lenovo Carbon X1 Gen 6 with Windows 11. There have been a series of recent Lenovo Power Management (PM) driver updates via the Windows update. It may be that one of these driver updates that has fixed the keyboard issue. I have not noted any fixes listed in the Windows system updates for this keyboard problem.
    The driver updates are:
    Version 1.69.132.0 Lenovo PM Device
    Version 4.3.13.0 Lenovo Smart Standby System
    Version 10.2.4.1 Lenovo Power & Battery
    Edit: As of 20 February 2026, the non-functional keyboard problem persists. The problem reoccurs intermittently, necessitating a restart of the laptop. The work around is to disable, 'Fast Start-up' in the Control Panel, as previously reported. The intermittent nature of this problem is unknown and there appears to be no logical explanation that I can think of.
  3. bob bob 30 Reputation points
    2026-02-09T18:51:50.0333333+00:00
    yup, and looks like its back again, with the web browser this time. Not sure if its with webroot or Microsoft.
    So the little green checkmark doesn't show up next to sites in Microsoft edge.
  4. Daniel Hart 10 Reputation points
    2026-03-02T18:48:15.6433333+00:00
    I have attempted turning off 'fast start.up' and rebooting my laptop. I have attempted uninstalling drivers and updating drivers. I have tried entering BIOS and restoring defaults.
    None of these solutions have worked.
    Not sure what to do at this point
