Does Microsoft have a fix for the common issue with laptop keyboards not working after Windows 11 Updates
Patrick Richey 45 Reputation points
2025-10-31T19:23:39.99+00:00
I have had multiple laptops, multiple brands, having their keyboards stop working after doing Windows 11 Updates. So far, the only temporary fix I have found is to delete the Standard Keyboard Driver, reboot, then the keyboard will work again until the next shutdown. Then I have to repeat the process. Does anyone have a real and actual fix for this issue? I've been through dozens found with Google, none of them actually work though. I'm used to having issues in Windows and I can usually figure out a fix for them, but this one actually has me stumped! I've already updated the BIOS to the latest version, performed all the latest Windows Updates, Disabled the Filter Keys, Reinstalled the Keyboard Driver, Ran SFC and DISM, and some other things I found online. FYI, I can plug in an external USB Keyboard and it will work, even after shutting down and restarting. This has happened on HP, Dell, Lenovo, and ASUS laptops. The only common denominators I have found so far is Windows 11 and the Standard Keyboard Driver. Currently it is happening on one with a fresh install of Windows 11 Pro using the Standard 101/102-Key or Microsoft Natural PS/2 Keyboard for HP Hotkey
Support. I'm looking forward to receiving positive input on this issue.
Hendrix-V 18,605 Reputation points Microsoft External Staff Moderator
2025-11-01T02:27:55.2566667+00:00
Hi Patrick Richey,
Thank you for reaching out to the Microsoft Q&A Forum! You’ve already done a lot of the right troubleshooting steps, so let’s focus on what usually resolves this issue permanently.
The behavior you described (internal keyboard stops working after Windows 11 updates, works again only after uninstalling the Standard PS/2 driver, external USB keyboard always works) points to two common causes:
  • Fast Startup restoring a bad driver state after shutdown.
  • OEM hotkey filter drivers (from HP, Dell, Lenovo, ASUS) interfering with the keyboard class in Windows.
Here is my suggested solution on what you can do to fix it:
Disable Fast Startup
  • Go to Settings → System → Power → Additional power settings → Choose what the power buttons do → Change settings that are currently unavailable, then uncheck “Turn on fast startup” and save.
    • Or run this command in an Admin terminal: powercfg /h off
  • Then perform a full shutdown to test: shutdown /s /t 0
The initial response might not address the problem. So, if your problem persists or you need any assistance, feel free to ask me by clicking "Add Comment". Thanks for your effort.
If the answer is helpful, please click "Accept Answer" and kindly upvote it. If you have additional questions about this answer, please click "Comment".
16 additional answers
  1. bob bob 30 Reputation points
    2025-11-19T14:56:52.49+00:00
    yes same here, multiple people/businesses have the same issue, tried updates of the drivers etc.. strange because after you boot up doesn't work but if you do a restart after the boot it works but only with a restart. (Also works in Bios before it gets to windows every time.)
    Anyone have a ETA or any other insight on this?
  2. Nigel Nelson 30 Reputation points
    2025-11-23T20:29:35+00:00
    After talking to a Windows support agent, I used Windows ISO [Windows Installation Assistant] to reinstall Windows 11, and touch wood - that seems to have fixed the No keyboard at log on problem. Was careful to tick the keep my documents and Apps/programmes box. Last resort as it takes sooo much time. But so far its working fine.
  3. Nigel Nelson 30 Reputation points
    2025-11-24T10:39:12.4566667+00:00
    As post above.
  4. lewis bragg 10 Reputation points
    2025-12-08T23:04:01.0133333+00:00
    As of Dec 5, I still had the issue with unresponsive keyboard. I gave up on a fix from Webroot/Microsoft after 2.5 months. I uninstalled Webroot and went with another company. Problem solved, no issues so far.
