Does Microsoft have a fix for the common issue with laptop keyboards not working after Windows 11 Updates
Patrick Richey 45 Reputation points
2025-10-31T19:23:39.99+00:00
I have had multiple laptops, multiple brands, having their keyboards stop working after doing Windows 11 Updates. So far, the only temporary fix I have found is to delete the Standard Keyboard Driver, reboot, then the keyboard will work again until the next shutdown. Then I have to repeat the process. Does anyone have a real and actual fix for this issue? I've been through dozens found with Google, none of them actually work though. I'm used to having issues in Windows and I can usually figure out a fix for them, but this one actually has me stumped! I've already updated the BIOS to the latest version, performed all the latest Windows Updates, Disabled the Filter Keys, Reinstalled the Keyboard Driver, Ran SFC and DISM, and some other things I found online. FYI, I can plug in an external USB Keyboard and it will work, even after shutting down and restarting. This has happened on HP, Dell, Lenovo, and ASUS laptops. The only common denominators I have found so far is Windows 11 and the Standard Keyboard Driver. Currently it is happening on one with a fresh install of Windows 11 Pro using the Standard 101/102-Key or Microsoft Natural PS/2 Keyboard for HP Hotkey
Support. I'm looking forward to receiving positive input on this issue.
Hendrix-V 18,605 Reputation points Microsoft External Staff Moderator
2025-11-01T02:27:55.2566667+00:00
Hi Patrick Richey,
Thank you for reaching out to the Microsoft Q&A Forum! You’ve already done a lot of the right troubleshooting steps, so let’s focus on what usually resolves this issue permanently.
The behavior you described (internal keyboard stops working after Windows 11 updates, works again only after uninstalling the Standard PS/2 driver, external USB keyboard always works) points to two common causes:
  • Fast Startup restoring a bad driver state after shutdown.
  • OEM hotkey filter drivers (from HP, Dell, Lenovo, ASUS) interfering with the keyboard class in Windows.
Here is my suggested solution on what you can do to fix it:
Disable Fast Startup
  • Go to Settings → System → Power → Additional power settings → Choose what the power buttons do → Change settings that are currently unavailable, then uncheck “Turn on fast startup” and save.
    • Or run this command in an Admin terminal: powercfg /h off
  • Then perform a full shutdown to test: shutdown /s /t 0
The initial response might not address the problem. So, if your problem persists or you need any assistance, feel free to ask me by clicking "Add Comment". Thanks for your effort.
If the answer is helpful, please click "Accept Answer" and kindly upvote it. If you have additional questions about this answer, please click "Comment".
16 additional answers
  1. Bluedog 15 Reputation points
    2025-11-10T15:15:01.4366667+00:00
    I'm seeing that a Microsoft update should be out Tuesday for this after researching online. Once again, I have a Lenovo IdeaPad, and two new Lenovo All in one desktop that I haven't even ran yet. I turned both computers on out of the box signed in and had the problem. Expecting a call back from Lenovo today. Hope to hear this is true about the updates.
  2. Nigel Nelson 30 Reputation points
    2025-11-08T18:14:01.3766667+00:00
    I just contacted Microsoft support and this is the message I got: "Thanks for clarifying — that’s an important detail. If your keyboard functions in BIOS but not at the Windows login screen, it strongly indicates that the issue lies within Windows itself. Yes, Microsoft is aware of the widespread keyboard problem following recent Windows 11 updates, and we are actively working on a fix." So they are aware of the problem and hopefully we will get a fix for it. Hopefully...
  3. David Hutton 0 Reputation points
    2025-11-06T17:08:35.54+00:00
    We have been seeing the same issue on Dell and Lenovo PC's. After uninstalling the keyboard driver in Device manager, restarting the laptop it would work briely. If you restarted the laptop again it would stop working. we have even come accross the mouse failing as well.
    Uninstalling update KB5066835 helped with one device. Then after a repoot issue kicked in again.
    Just hope Microsoft have identified this and look to get a fix in place soon.
  4. Nigel Nelson 30 Reputation points
    2025-11-05T10:56:10.4466667+00:00
    I've had the same problem since installing a Windows update about a month ago - so I fix it, and it occurs again every time I install a windows update. I have an Acer laptop. The fix I use is - restart/go into BIOS [F2 at start] and restore system defaults [F9]/Then "Exit" Save and close. Then reboot. It works till the next Windows update.
