Recently I have been having a problem where my game mode is automatically turned on when I start my pc and I have to enable it every time I boot my pc, does any one have a fix for this?
Aaron Gill 0 Reputation points
2025-10-31T15:48:39.21+00:00
Windows for home | Windows 11 | Gaming
    2025-10-31T15:49:30.2966667+00:00
    If your Game Mode is automatically turning on every time you start your PC, you may want to check the settings related to Game Mode in Windows 11. Here are some steps you can follow to troubleshoot and potentially fix the issue:
    1. Check Game Mode Settings: Go to Settings > Gaming > Game Mode and ensure that the settings are configured correctly.
    2. Registry Settings: You can check the registry values associated with Game Mode. The relevant registry key is located at HKCU\Software\Microsoft\GameBar. Ensure that the AutoGameModeEnabled value is set correctly.
    3. Update Windows: Make sure your Windows is up to date, as updates may contain fixes for issues related to Game Mode.
    4. Reinstall Game Mode: If the problem persists, consider reinstalling or resetting the Game Mode feature through the Windows settings or using PowerShell commands.
    If none of these steps resolve the issue, you may want to consult Microsoft support or community forums for further assistance.
  2. Arlene D 36,225 Reputation points Independent Advisor
    2025-10-31T17:59:15.7333333+00:00
    Thanks for reaching out. Does Game Mode turn off every time you restart even after enabling it in Settings?
    Go to Settings > Gaming > Game Mode and make sure it’s set to On. Then check for any Windows Updates under Settings > Windows Update, as newer updates include fixes for Game Mode. Also, confirm you’re signed in with your Microsoft account since some gaming settings sync with your profile. If it keeps resetting, run the Windows Store Apps Troubleshooter from Settings > System > Troubleshoot > Other troubleshooters to refresh system gaming components.
