Region issue
Ben H 10 Reputation points
2025-10-23T01:38:45.35+00:00
I have a Windows 10 version 22H2 (build 19045.6456) PC that although the region is set to the United States, dates are appearing in DD/MM/YYYY format in websites, and language is appearing in UK English.
I have attempted the below troubleshooting steps:
  • Confirmed the time zone is set correctly in Settings > Time & Language > Date & time
  • Confirmed the region is set correctly in Settings > Time & Language > Region
  • Confirmed the language is set correctly in Settings > Time & Language > Language
  • Confirmed the region as well as the date formats are set correctly in Control Panel > Clock & Region > Region
  • Confirmed the time zone is set correctly in Control Panel > Clock & Region > Date and Time
  • Verified I am on the US versions of the websites
However, the system clock is showing in the correct date format. Any help would be appreciated. Thank you!
Windows for home | Windows 10 | Desktop, Start, and personalization | Other
  1. SD - IA 179.1K Reputation points Independent Advisor
    2025-10-23T02:53:12.19+00:00
    Hi Benjamin,
    The Settings are correct.
    May I see a screenshot of edge://settings/languages page to investigate further?
    I look forward to your response and am eager to collaborate until we find a solution.
