Managing profiles, sync settings, and sign-in options in Edge on Android
Sync not working with the latest version of Edge Linux. I am able to sign in to my account, but when I turn on the Sync nothing happens. I even reinstalled the app and same issue.
I also tried the latest Dev build and that does not work either. I am also using the latest version of Kubuntu.
I have an older version of Edge Linux on my laptop and the Sync is working.
Hello, good day and thanks for your question. Sorry to know about this. You may also check and test to see if this is also happening on the Beta version that you can download from the link below. If you are looking for a different or lower version that you want to install, you can also check out the other link below as well.
https://www.microsoft.com/en-us/edge/download/insider?cc=1&cs=2282084340&form=MA13FJ
https://www.microsoft.com/en-us/edge/business/download?form=MA13FQ
In this case, it is highly suggested to send a feedback to the team that is working on Edge for them to check on and correct this and you can either cascade it from the browser itself or from the link below.
https://techcommunity.microsoft.com/category/microsoftedgeinsider
