ISO & iPadOS excel freezing problem
Jem 25 Reputation points
2025-10-21T13:09:41.1466667+00:00
I am writing to formally raise a complaint regarding a recurring issue with Excel on my iPad Pro. The application frequently freezes while in use, which is severely affecting my productivity.
I have already attempted to resolve the problem by reinstalling the app, but the issue persists. Despite my efforts, the app continues to freeze, making it difficult to work efficiently.
I kindly request immediate assistance to address and resolve this issue. If there are any troubleshooting steps or updates that could fix the problem, please provide guidance as soon as possible.
I would appreciate your prompt attention to this matter and look forward to your response
Microsoft 365 and Office | Excel | Other | iOS
GsN5034 - IA 76,990 Reputation points Independent Advisor
2025-10-21T13:48:10.62+00:00
Hello, thank you for reaching out to Microsoft Q&A.
I understand that the Excel app on both your iPhone and iPad crashes or becomes unresponsive when you try to open it.
Several users have reported that the Excel program is unresponsive or freezing on iOS devices after the recent updates. As a workaround, you can turn off your Wi-Fi or enable Airplane mode when the app freezes. Once you regain access, you can reconnect to Wi-Fi or disable Airplane mode.
Another option is to close the Excel app from the recent apps section.
  • Restart your iPhone or iPad.
  • Relaunch the Excel app.
If the issue continues, go to Settings > Excel > Reset > Reset Cloud Settings.
Restart the Excel app.
0 additional answers
