how can i cantact ot system aministrator
indadur rahman 0 Reputation points
2025-10-14T14:15:18.6633333+00:00
how can i cantact to my laptop system aministrator
Microsoft Edge | Install and update | Windows 10
    2025-10-14T15:09:31.7766667+00:00
    Thanks for reaching out, I'll help you figure out the best way to contact your system administrator. First, is your laptop personally owned or issued by your company or school? If it’s managed by an organization, do you see any company name or email listed under Settings then click Accounts then Access work or school? Are you connected to a work or school domain, like through Microsoft 365 or Google Workspace? Do you have access to any internal tools like Microsoft Teams, Slack, or a helpdesk portal where IT support might be listed? Have you received any emails or notifications from IT or support before? Also, are you trying to fix a specific issue that requires admin access, like installing software or changing system settings? If you’re seeing a message that says “Contact your system administrator,” could you let me know where exactly that appears, on startup, during login, or when opening a specific app? Lastly, are you connected to a stable network when this happens?
