All bluetooth headset mic is not working with Window 11
Timothy Liew 160 Reputation points
2025-10-14T00:19:06.91+00:00
mic is not working for all bluetooth headset. The bluetooth show connected with both sound and mic, but there are none of Window program can access the mic function. FYI, before the Window Updates, everything is fine.
Microsoft Teams | Microsoft Teams for business | Settings | Other
  1. ddvor 35 Reputation points
    2025-10-29T21:30:07+00:00
    Same thing here: on 3 different sets of Bluetooth headsets: only the headphones or only the microphone can be enabled at any one time. This behavior started immediately after the Windows 11 25H2 update was installed.
    • If the headphones are set as the output, the microphone is produces no input and just clicks once when you try to engage it, oftentimes crashing whatever software is trying to use it.
    • If the microphone is enabled first, then it will work, but the headphones will not and won't output any sound.
    • Everything works as long as you set the input and output devices to be different.
    The machine is a Lenovo X1C G13 with the Intel BE201 Bluetooth chipset and the latest Intel 23.160.0.9 driver as of 10/29/2025 (driver build date is 7/20/2025). The headsets I've tried were 3 different models and generations of Bose wireless headphones and earbuds.
    Solutions attempted:
    • Rebooting
    • Removing the Intel Bluetooth device, reinstalling device and driver
    • Rolling back Bluetooth driver to 4/2025
    • Upgrading driver to the newly-released 23.170.0.3
    • Removing and Re-adding headsets
    Update: the solution ended up being updating to the 26200.7019 (or 26100.7019 for 24H2) preview build of Windows by installing KB5067036 manually, along with updating the Intel BE202/BE201/BE200 driver to version 23.170.0.3 and rebooting.
  2. ddvor 35 Reputation points
    2025-10-29T23:03:59.09+00:00
  3. Simon B 0 Reputation points
    2025-10-30T11:10:24.09+00:00
    I just went through some instructions of an article I found here: https://www.tweaktown.com/guides/11208/microphone-not-working-in-windows-11-heres-the-solution/index.html
    It recommended to to disable audio enhancements. Which by the way did not work for me. By accident I found that the recording device does actually record something but I do not see any sound level in the System Sound menu.
    Might this provide some more information for somebody who knows how those things work?
  4. Vogel, Willy 0 Reputation points
    2025-10-30T15:28:17.6266667+00:00
    I have also 2 different Bluetooth Headsets and a Lenovo Think Pad T14 Gen 5, installed the recommended, the newest bluetooth intel drivers, uninstalled them removed and added the headset several times with restarts between all steps - MS Teams is not working with them, no sound, no mic. They worked in mid 2025 and on other devices well.
    Please fix this.
  5. Glen G 0 Reputation points
    2025-10-31T14:09:48.02+00:00
    I'm just throwing a log on the fire and saying I have the same exact issue. Doesn't matter what Bluetooth headset I use: no microphone on a Lenovo ThinkPad X1 Carbon Gen 12. I've tried every single thing recommended in this thread, a suggested registry fix from Kimi, resetting Windows Audio and Bluetooth services, unpairing and repairing about a dozen times. No dice.
    Issue persists on a Yealink headset with USB dongle, a Plantronics Voyager 5200 paired via Bluetooth, and Sony Bluetooth headset. Maddening. I'm rolling with a wired headset for the time being which works fine.
