All bluetooth headset mic is not working with Window 11
Timothy Liew 160 Reputation points
2025-10-14T00:19:06.91+00:00
mic is not working for all bluetooth headset. The bluetooth show connected with both sound and mic, but there are none of Window program can access the mic function. FYI, before the Window Updates, everything is fine.
Microsoft Teams | Microsoft Teams for business | Settings | Other
  1. Vivian-HT 17,900 Reputation points Microsoft External Staff Moderator
    2025-10-16T08:03:40.7+00:00
    Dear @Timothy Liew,
    I’m truly sorry you’re still experiencing issues with your Bluetooth headset, especially trying all the troubleshooting steps. I know how disruptive this is when you use your mic for calls and work. Thank you for your patience and for the steps you’ve already tried.
    Because the problem persists after trying all the above troubleshooting steps, the fastest and most effective way to resolve this is to work directly with Microsoft Support. They have the tools and resources to perform deeper diagnostics and apply advanced fixes for Bluetooth and audio issues, especially those caused by recent Windows updates.
    Contact Microsoft Support:
    Step 1:
    Step 2:
    • Enter your issue in general in the box below "We're here to help" then click "Get Help"
    • Scroll down and click on Contact Support then log in to your personal Microsoft account (If the account cannot be logged in, you can use another account or create a new account to execute)
    • Select "Window" in Products & Services, select "Devices and Drivers" as a category, and click Confirm
    • Select "Chat in a web browser and support specialist" to enter the chat window
    Note: Please be reassured that you are not alone, I’ll continue to monitor this case and will reach out to you with any new updates as soon as possible.
    I hope this information is helpful. Please follow these steps and let me know if it works for you. If not, we can work together to resolve this.
    Thank you for your patience and your understanding. If you have any questions, please feel free to reach out.
    I'm looking forward for your reply.
  2. Steven Goldsmith 0 Reputation points
    2025-10-14T14:24:16.38+00:00
    Windows 11 Pro 25H2 26200.6584 Windows Feature Experience Pack 1000.26100.234.0 Blue Parrot B450-XT II v1.05
    This stopped working a few days ago. It worked for 2 months. The headset works on other devices. When you select headset for mic in an app the speaker just clicks. One time it rebooted the machine. I need these for work. I tried another headset and the same issue.
    I ran Audio and Bluetooth troubleshooter, and it seemed to fix the issue. Just leaving this for others to try.
  3. Vivian-HT 17,900 Reputation points Microsoft External Staff Moderator
    2025-10-14T05:23:56.76+00:00
    Dear @Timothy Liew,
    First, I want to sincerely apologize for the frustration this issue has caused. We understand how important your headset is for daily work, and we truly appreciate your patience while we work through this together.
    We’ve seen similar cases recently after Windows 11 updates, and while we’re doing everything we can to assist, this may require deeper troubleshooting with Microsoft Support to ensure a permanent fix.
    Therefore, could you please try the following steps so we can narrow down the issue?
    1/ Confirm your headset model
    • What is the exact brand and model of your Bluetooth headset?
    • Do you have more than one headset, and does the issue occur on all of them?
    • Does the headset microphone work correctly when paired with another device (e.g., phone or tablet)?
    • Which Windows 11 version and build are you currently running? (For example: Windows 11 Home or Window 11 Pro)
      • You can check this by pressing Win + R, typing winver, and sharing the version and build number. For Microsoft's instruction: What version of Windows am I running?
      • If possible, please provide a screenshot to help us diagnose the issue more effectively.
    2/ Test the microphone in Windows
    • Go to Settings > System > Sound > Input.
    • Select your Bluetooth headset and check if the input level bar moves when you speak.
    User's image 3/ Test the microphone in Microsoft Teams
    • Open Teams, go to Settings > Devices, and select your Bluetooth headset as the microphone.
    • Use the Make a test call option to confirm if it works.
    Moreover, here are some additional steps I recommend you try:
    Step 1/ Create a New Windows User Profile Sometimes profile corruption after an update can cause audio issues. Please create a new local user account and test the headset there. (Settings > Accounts > Other users > Add account)
    Please follow the Microsoft instruction here*:* Manage User Accounts in Windows
    If It Works in the New Profile This suggests the issue is tied to your current profile, likely due to the recent Windows update.
    Step 2/ Revert to Previous Windows Version (Optional)
    If you've recently installed a Windows Update and the update is causing your device to have errors or other issues, uninstall the update to try to resolve the issue. Please follow the Microsoft Official Guide here: How to uninstall a Windows Update
    __Important: __Before uninstalling a security update, make sure you understand the risks. If you're using Windows 11, try to reinstall your version of Windows first.
    These steps help us confirm whether the issue is with Windows, the headset, or the app. Please follow these steps and let me know if it works for you. If not, we can work together to resolve this.
    Note: Please understand that as forum moderator, I don’t have access to the backend systems to troubleshoot this effectively due to privacy and security constraints. I am just organizing use cases and collecting data, including from you, on a daily basis and will continue to monitor the progress of this issue.
    Thank you for your patience and your understanding. If you have any difficulty, please feel free to reach out.
  4. Vivian-HT 17,900 Reputation points Microsoft External Staff Moderator
    2025-10-14T01:22:14.26+00:00
    Dear @Timothy Liew,
    Thank you for posting your question in the Microsoft Q&A forum.
    Bluetooth headset microphones stopped working on Windows 11 after an update, even though the system shows them as connected. This is a known issue after recent Windows 11 updates, especially with version 24H2, and it’s usually related to driver or profile handling changes.
    Therefore, here are some steps I recommend you try while waiting for further investigating:
    Option 1: Update Drivers
    • Right-click on the Start menu and then select Device Manager.
    • In Device Manager, expand Bluetooth and Sound, video and game controllers, then:
      • Right-click your Bluetooth adapter > Update driver.
      • Do the same for your audio drivers.
    • In the Update Drivers window that opens, select Search automatically for updated driver software. Windows proceeds to search for updated drivers. If it finds any, it installs the updated drivers.
    If Windows doesn't find updated drivers, updated drivers can be searched from Windows Update by selecting the option Search for updated drivers on Windows update. From there, follow the instructions in the article Automatically get recommended drivers and updates for your hardware.
    Option 2: Reset Bluetooth Stack
    • Remove your headset: Settings > Bluetooth & devices > Devices > Remove device.
    • Restart your PC.
    • Re-pair the headset.
    Option 3: Make sure apps have access to the microphone
    If your microphone isn't detected after updating Windows 11, you may need to give your apps permission to use it. Here's how:
    • Select Start > Settings > Privacy & security > Microphone and make sure Microphone access is turned on.
    • Make sure Let apps access your microphone is turned on, then choose which apps have access. Desktop apps won't appear in this list.
    If you want to give access to desktop apps, make sure that Let desktop apps access your microphone is turned on. You can't turn off microphone access for individual apps.
    If your camera contains a microphone, you might also need to give your apps permission to use your camera.  If so, select Start > Settings > Privacy & security > Camera and make sure Camera is turned on.
    Option 4: If others can't hear you
    Try the following solutions:
    • If your headset has a Mute button, make sure it isn't active.
    • Make sure that your microphone or headset is connected correctly to your computer. If your headset is a wireless Bluetooth device, make sure your Bluetooth device is paired and connected by following the steps at Pair a Bluetooth device in Windows.
    • Make sure that your microphone or headset is the system default recording device. Here's how to do this in Windows 11:
      • Select Start > Settings > System > Sound.
      • In Input, go to Choose a device for speaking or recording, and select the device you want.
      • To test your microphone, speak into it. In Volume, make sure the blue bar moves to make sure Windows hears you.
    • Run the Recording Audio Troubleshooter. Select Settings > System > Troubleshoot > Other troubleshooters. Select the Recording Audio troubleshooter.
    Additionally, if you are having trouble with your microphone features, or with the microphone on your headset or webcam, the following information can help you troubleshoot and resolve issues. Please follow the Microsoft Official Guide here: Fix microphone problems
    Option 5: Run the Windows Bluetooth troubleshooter
    You can start by running the automated Bluetooth troubleshooter in the Get Help app. It will automatically run diagnostics and attempt to fix most Bluetooth problems. If you are using an older version of Windows or a mobile device, please skip to Common Bluetooth issues in Windows 11 section.
    If the Bluetooth troubleshooter in Get Help app is unable to resolve your issue, select your specific Bluetooth problem from the Common Bluetooth issues in Windows 11 section below and follow the provided steps. If your issue is not listed, refer to the General Bluetooth troubleshooting in Windows  11 section and follow the outlined steps there.
    For more information and instruction (Bluetooth troubleshooter and troubleshooting steps), please follow the Microsoft Official Guide here: Fix Bluetooth problems in Windows
    Please understand that our initial response does not always resolve the issue immediately. However, with your help and more detailed information, we can work together to find a solution.
